I have a 30 x 40 foot pole barn that is un insulated in ne ohio except for the garage doors. I am trying to heat the garage to a manageable level in the winter time. I would like to put fiberglass batts on the roof trusses to keep my heat in. I will be using 2 kero heaters to provide the heat in there.
Do I need to worry about moisture above the insulation? The roof is asphalt shinlgles and sheating is just plywood...I can do the whole roof for about 500 in fiberglass r13 batts...I think it will help quite a bit having this insulation up there.
Any suggestions or concerns I should be worried about?
Thanks for all help,
Grub
Grub
