roof leaking??
brett3xx
I need some suggestions on how to fix my roof leak. I have a few pin holes in the metal that are letting water in. I dont have the money to replace the roof so I need some temporary suggestions. I tried cool seal, but it didnt do much at all. Ill attach a few pics. The holes are mainly in this one area. but there are a few others scattered about. I considered trying to replace the 6 metal panels that are the worst, but Id prefer to just put some type of sealant over the entire roof. Any ideas?
Red05GT
ohio
Get some metal siding/roofing screws with the rubber washers and run those into the
holes and then coat with clear silicone.
Stuart in MN
Minneapolis
Unfortunately, if the metal is thin enough to get pinholes you're just going to keep chasing leaks as more pinholes appear.
brett3xx
could I just replace the panels that have the pinholes? do I have to remove the old panels to install the new panels?
oldgoaly
Shiloh, Il
We live on a farm, newest building older than me (55+). The white elastomeric coating is the best we have used. We have steel and aluminum roofs, we replace loose nails with screws and have used a roller and brush to apply the coating. But since it has work so well we bought one of the bigger airless / pump sprayer to do the roofs. It has sealed many birdshot holes and bad joints it takes a couple of coats, do one on a Saturday, the another Sunday. Wait till the dew is evaporated, the coating is slick when wet!!!! And yes it does lower attic / building temps. tt
Printer Mike
Eatonton, Georgia
Can you walk on the roof? Maybe light up your shop as bright as possible on a dark night, and carefully walk the roof looking for light leaks. Neoprene caulk works good for me on my flat metal print shop roof.
Bevis
Moore Haven, Florida
Yes you can just remove the old panels and put the new ones in. I just help a friend do that today, looked like his panels were shot with a shotgun.
brett3xx
thank you all for the great ideas, I ended up getting some roofing cement and spreading it over the holes with a trowel, it rained all day today and no leaks!!
