roof osb thickness
justin1795
blue grass IA
im planning on putting a pole barn up and sheeting it with osb and doing asphault shingles. I called they city to see requirements on thickness and they weren't very helpful. they said ask the builder. I said so is there no requirement? they said there is. I said well what is it and they said your builder should know. the trusses will be 4 foot apart more than likely.
kd3pc
Northern Neck
My trusses are only 2' apart and I used 1/2" nominal with hurricane clips. Not sure I would use 1/2" on 4' centers...would go at least 5/8 with clips, if not 3/4"
If there is zoning or AHJ, make sure the markings are facing down in to the work space where they can "see" the stamps and clips.
Best of luck
My son had to pay extra to upgrade from 7/16" to 1/2" OSB when he had his roof re-decked. Clips are a must for any rafter spacing larger than 16" OC.
With 4' rafter spacing I would seriously consider 2x4 purlins under each horizontal joint.
Red05GT
ohio
You will have to use purlins. Even 3/4" osb or plywood would not handle a 4' span.
Falcon67
Merkel, TX
7/16" OSB will span MAX 24" with clips. Same AFAIK with the slightly thicker stuff. 48" is way too far.
Broncoman75
On houses (2ft truss spacing) we use 5/8" osb. if you have to use 7/16 then clips are required. I would suggest as others have said to run purlins or add more trusses.
If you were to do a metal roof, you don't need sheeting, just purlins to screw the tin onto and it should outlast shingles....
Zeke
You couldn't do this w/o purlins clips or not. AFA calling the city, they cannot give advice over the phone and usually won't give it in person. However, they often times have handouts of 'typical' building requirements. You will find span tables on these generic plans.
It's the old deal with inspectors, they will tell you all day long what's wrong but they won't tell you how to fix it.
Hey, Broncoman, took you long enough to chime in. Welcome to live chat. :p
Kevin54
MEMBER EMERITUS
Urbana, Ohio
^^^^This^^^^
Even on 2' spacing between rafters you can feel the flex when walking on the roof. I would put 2x4's down as stated to make it a rigid roof.
J
justin1795
blue grass IA
the hoa wants it to look like the house. they had some steel roofing at the farm show that had texture to it but it was over 3x the price.
icenfire01
South Dakota
I would add some trusses, they are relatively cheap. 24" OC with 1/2" osb on that. No hurricane clips, but probably should have, cheap insurance.
icenfire01
South Dakota
Don't forget about your ceiling, It will make life a lot easier when you put up a sheet rock or tin if your trusses are 24" oc.
J
justin1795
blue grass IA
well I got some good news the HOA says a steel roof is ok. so when doing the steel roofing are most guys putting sheeting underneath?
Diesel Dan
TN
I did, much quieter and with 100% support it is much less likely to be damaged by hail.
Bib Overalls
Jonesboro, Arkansas
To my eye metal looks better over sheeting with felt in between. Subtle but discernible.
Neighbor across the road used 7/16 OSB on 24" spaced trusses. Spec grade shingles. I can make out every sheet of OSB. It dips between the trusses. We used 5/8 and premium architectural shingles. Flat as a, well, board.
