Roofing bolt /gutter bolt tooling
damienga15de
Does anyone make a driver for roofing/gutter bolts, iv a lot of cable tray to make up in the next few weeks I'm tired of using a large flat head screwdriver they don't get enough grip. A 11mm spanner works ok on the nuts but the heads are a pain.
D
damienga15de
It's not a p3 the cuts in the head are flat and shallow. I'm going to make up a bit for my 10.8v impact
jakemac
New England
Find a p3 or p4 bit with long grooves in the tip. Then grind the tip down to get the + profile you need.
volleyball
NY, not NYC
You'd also may have to grind down the v between blades as the p3 tends to round out to shaft diameter.
What about a drag link slotted bit?
