Gn.....I tried the whole house fan.....I got as good if not better results with the wind powered turbine on the roof.
I have vents on my gables....and that was where I put the whole house vent fan. Problem is, depending on which way the wind was blowing, it was either helping or pushing against.
About the only other option I might consider is a solar powered vent fan that sits on top and pulls air out that way vs pushing it out one of the gable vents.
Next year I plan to redo the wood on the gable vents and will most likely get rid of those vents. I have enough soffit vent to keep it all cool.
I've attached pics of my roof when I did it myself 15 or so years ago....I had a lot of wood damage. I spent a whole week just fixing the damage....and another 3 weeks nailing on the shingles. Every evening after work...2-3 hours of nailing. Next time I'm just writing a check.
As you can see from the pics.....I've made a few 'modifications'....
Holy ****... that's a hell of an addition! I knew you added on, but that is something else. Did you double your space?
Our roof is similar in that it's low, but we don't have the structure on top with the gables. We do have one gable end with no venting. On the other end of the house we have a hip and it gets really hot there and happens to be over the master. I wish they would have built the house with a gable there. I may need to add a vent at the gable end and a dormer on the hip end because these areas seem like there is no air flow in these areas. I've also thought about the solar powered vent fans on at least the area over the master.
I can see I have a little bit of research to do. I want to make sure this thing is done right. The last thing I want is to think I should have [fill in the blank].
