olytdi
Tell me you think this is viable:
I have a 28x28 pole barn with a shallow pitch roof (4/14) under a bunch of very large and very productive trees. I have an on-going problem with accessing it safely to get branches and leaves off. It's corregated steel and slipperier than snot even when dry. On the front side of the building, it's a 12 ft drop if I fall. On the back, it's about a 16 ft drop. I don't want to fall and access to the roof by ladder is not only difficult due to a slope in the back, but I cannot reach very far up the roof from the ladder.
I've pondered and pondered how I might be able to get up there and clean-off the 4 inches of detritus that builds up over a year and came-up with this idea: there is a 10"x12" main post on each end of the building from floor to peak. These are just inside of the siding and support the two end trusses. My thoughts are to take say, 2.5" galvanized pipe and strap a 3 or 4 ft piece vertically along the outside of each end of the building along these posts such that the pipe extends up through the eve and above the peak. So, there would be a roof peak with a piece of pipe extending up above by a foot or so on each end of the building. I feel that I could cut through the roof to do this because that part of the roof on each end is outside of the building has an 18" overhanging eve. So any leaks presumably would occur outside of the building not inside.
Perminently fastened between these pipes would be a length of wire rope that would reside about a foot above the peak strung from end to end. I would then use this secured cable to clip into with my harness and be able to walk around without fear of falling. Because the attachment cable would be free end-to-end along the peak, I would have unfettered ability to move from end to end of the roof.
Does this make any sense? What am I missing --it can't be this easy can it?
Thoughts, critique, tips?
thanks!
thanks!
