I don't think anybody is saying that there shouldn't be certains standards in place, but anybody that has dealt with the process and the inspection process knows that it can get ridiculous. There needs to be a happy medium there somewhere especially when it comes to add-ons and "sheds".. When you have an inspector or permit guy come and not get out of his car, what's really going on there? Arguments on both sides, but I do believe in the statement that you need to educate yourself..
I can tell whether or not a house built in '73 was built correctly or not.
Just my 2-cents worth.
I whole heartedly agree. I put on an addition and went through hell with inspectors over a beam in the garage. Drove me crazy and held up my addition for 3 weeks.
I'm glad you have the knowledge to tell if your house was built correctly or not. I don't, that is not my area of expertise so I need to rely on someone else. Being my second home though, I am learning as I go like everyone has to do.
I am curious though...How can you tell if the rebar in the foundation is tied correctly, or if there are seismic straps under the siding and sheetrock, or if the wiring inside the walls is done right, of if there is the required 24" x 24" concrete post pad beneith your garage slab, or if the studs were nailed correctly inside the walls, ect... ect...
These are all things you cannot see so how can you tell? Just because the house looks to be done correctly from the outside does not mean that everything beneith the "skin" was done right. These are the exact places where builders will cut corners.
As a matter of fact, the county inspector probably saved me a ton of grief and maybe even my life. My addition was a 2 car garage and 2 bedrooms over it. When my builders installed the glu-lam spanning the width of the garage, they notched the ends incorrectly to fit over the top plates and on top of that they installed the thing upside down! I didn't know any better and apparently they didn't either. When the inspector came in to check the framing he noticed those issues. It was only then that I learned that glue-lam beams have a specific top and a bottom and are pre stressed with an arc. If they are under a certain certain length it doesn't matter but I was over by 6 feet. You also cannot notch the ends like they did because it ruins the integrety of the wood in the ends.
Personally I am glad the inspector found those things and made my builders correct them. Like I said, I didn't know although you may have.
If your wife went out and bought a new car, would you expect her to go and learn all about auto mechanics just to be able to drive it, no.
I have lived in several houses and the whole process IS the education. I don't need to be a builder just to own a home or be an electronic engineer just to buy a new radio. But you learn as you go.
