Room Inside!
JOHN1
NEW TO THIS FORUM!
THANKS FOR HAVING ME
I HAVE A METAL BUILDIG ABOUT 30'x40'
I HAVE EXPLORED ALL AVENUES TO INSULATED THIS BUILDING RESONABLY PRICED BUT UNSUCESSFULL.
I THOUGHT MAYBE I SHOULD BUILT A "ROOM" INSIDE OF THE EXISTING BUILDING
I FEEL I COULD INSULATE, HEAT AND COOL IT BETTER.
ANY IDEAS APPRECIATED.
IT A AN "OVAL" SHAPED BUILDING?
THANKS
JOHN:confused: :confused: :confused:
D-Cal
Edmonton
I would look into spray foam insulation. Goes on quick, insulates better than batts and adapts to any shape. Specify the thickness you want applied, choose your R value to be whatever you want. No dust, little mess, in and out of your shop in probably an afternoon at most.
imported_banzaitoyota
Williston SC
Insulating the Pre-fab buildings is their MAJOR DRAWBACK.
I am using a combination of fanfold styrofoam panels/PLywwod strips/Radiant barrier F/B/F insulation
REFLEXX
Riverside, CA
That's the reason I went with a Miracle Truss hybrid building. But that doesn't help you, does it?
I'd 2nd the spray insulation!
