I have a oversized one car garage attached to side of home
When Home second floor was framed it was extended above garage also with full 8 foot ceiling and stick built framing. Here’s the question the second floor floor joists are sistered 2x6 x12 feet to center of garage with a triple 2x8 support then another 2x6x12 sistered to back of garage top plate. The floor is 3/4 osb t&g
Now 5 Years later I’d like to build a man cave in this attic space but not sure if I have a strong enough floor? Btw the 2x6x12 are 16inches on center
There is a full attic of stuff and the 5/8 drywall ceiling has no cracks in the garage ceiling. No real heavy items intended for man cave room No masonry fireplace or hardwood floors or slate pool table. Just couch large tv. Foosball table and small frig and bar. There is a full walk up steps with fire rated door in garage to get upstairs so finish work and use will be easy. Any thoughts if I’m ok with the floor framing? Also the 2x6x12,s were the rafters from the original one story garage glued and nailed together on 16 in center. Contractor said ok but too cheap to add larger floor joists. Thanks
He said it spans a single garage so I am thinking 12-14 feet range. Where is the OP? He probably fell through his weak floor joists and is in the hospital
