Rotary Hammer Drill Recommendations
sam.coll
Melbourne, Australia
I wouldn't waste money on a hilti, better to go middle of the road Bosch, Makita etc better user comfort ergonomics and vibration control than the HF. SDS max not required so why carry around the extra weight and the drill bits are more expensive.
Coach James
Sandhills of North Carolina
I have the HF SDS Plus and the HF SDS Max. I use the Plus for holes up to an inch and the Max for 1"+. I did several 1.5" diameter holes last year with it. They both work fine. A friend bought a HF SDS Plus to drill a bunch of holes for his deck and had no trouble.
I would spend money for good bits though. Most of my bits are Bosch and they hold up quite well. My Dewalts have also held up well. The only bits I have had lousy performance from are Vermont American. I have never used the HF bits.
Coach
kctyphoon
Jersey/Staten Island
Again, any brand will be fine for this. Get something sds plus. Sds max is bigger, heavier, but will actually drill slower more than likely. The HF model should be fine. All the big brand corded sds plus will be about the same. You can even get a cordless Milwaukee that would do these no problem. But money being a factor, just get something corded, and a decent bit like a Bosch.
Crazyjake8493
Upstate NY
For 1/2" holes, an SDS-plus like the Bosch Bulldog would be plenty. I got mine for $179 a few years ago and it's been great. Use quality bits like the Bosch Extreme bits, or the new Milwaukee bits.
If you foresee needing to do some chipping and light jackhammer type work, an SDS-max might be the better way to go. But for drilling only, I would buy a quality SDS-plus and you'll have it for future projects.
Collinsworth
london
I would recommend getting yourself either anSDS plus or anSDS max. They go through concrete like butter
The plus is smaller and the max is bigger/more powerful.
If this is the only project you were going to do with it I would just rent it
Where do you recommend renting it? do you have any more tools recommend renting?
SteveW1000
London, UK
London UK? If so HSS is the biggest chain of hire shops. Don't think there is much if any to rent in the big box stores. There are a number of smaller chains and independent hire shops around google is your friend.
Steve
Collinsworth
london
Steve
Thank you very much for your useful comment.
driftpin
I agree here. The SDS-MAX Harbor Freight tool (HFT) I have does well for the occasional use I give it, and doing demo work with it, the tool has held-up well. It certainly paid for itself in the first bathroom demo job I did. I did use the Harbor Freight bits, and did the entire job with the wide spade bit. Working on the next entire-bathroom demo, I did snap it, probably because I abused it, and I replaced it with a Bosch bit, which is still going strong.
The HFT round-hole drill bits have 4 carbide cutting surfaces, I found them to be acceptable for use in drilling 6" holes, easily and quickly. For me, it seems that vacuuming the dust out allows a faster cut. It also helped to cut-down on the airborne debris in the workspace.
I paid a recommended subcontractor to secure a steel-framed Hardi-board premanufactured 1-car garage to the slab poured for it (hilti threaded driven pins) . He used Dewalt cordless tools, and his drills couldn't do the job. I dunno if they were tired batteries, but watching them struggle, and asking them what they were gonna do to get the job done, and hearing, "continue what we're doing," I fired them on the spot. I used my HFT SDS-MAX to re-drill what they had started, and was done in < an hour.
