i was trying to decide between bosch
GBH2-28L (bulldog xtreme max) and
RH328VC sds-plus roto hammers...
www.boschtools.com
anyone know which is the newer product?
very similar price, weight, and other specs. aside from the obvious form factor difference (straight vs 90° build)...
GBH2-28L has slight edge in: amps, bpm, rpm, weight
RH328VC has slight edge in: max core bit diameter, and
maybe build quality (claims to have metal+plastic housing vs just plastic on the bulldog)?
they have clearly different anti-vibration mechanisms. the RH328VC has a shock absorber looking thing on it, and the bulldog has some internal mechanism you can't see.
different anti-kickback tech also. the bulldog's is electric ("uses an integrated sensor to stop tool rotation during bit bind-up situations"), and the RH328VC has a clutch ("clutch disengages torque transmission if the bit gets into a bind situation").
unlike the RH328VC, the bulldog can reverse direction.
anyway, i ended up going with bulldog xtreme max because i could get into it for cheaper, and it's not a tool i use that often.
i got it for like $120 shipped as a refurb from cpo (bought direct). used the new customer $20 coupon thing if you sign up for their spam. plus apparently 5% rakuten cash back.
