Guys, I need HELP!
Installing a used Rotary SPO7A lift. The left cylinder (away from the power unit) will not go up or down freely. It's a hydraulic issue as we have confirmed that the carriage is not bound or stuck, we've unhooked cables, etc.
When you raise the lift (empty or weighted), the left side squeaks, squeals and chatters as it goes up! It will not go down unless weight is applied (using a tractor bucket).
I've bled the cylinder, and got a little bit of air... Is this an air issue? Is there something major wrong with this cylinder? If so, how do you go about removing the it??
Thanks for any help you can provide!!
Robb
Robb
