Rotary or Challenger?? which is best?
thammel
Maryland
Getting ready to spring for a 2 post. 12' ceilings. Have narrowed down to Rotary SPOA-10-RA or Challenger CL10V3.
I'm not sure how important symmetric vs asymmetric is. This is for home use and not for trucks or even pickups. I want quality and safety.
I've read all the 2 vs 4 post stuff and like the apparent better access of a 2 post.
So...any comments or preferences on the above 2 lifts? I do want a clear floor lift. Any other recommendations for what fits under 144"?
Thanks,
Tom
zmotorsports
Northern Utah
I don't have anything to say about the Rotary lifts but I have the Ammco CV10 lift which is the same design as the Challenger Versalift and love it. I work on a wide range of vehicles and really wanted my posts in the symmetrical configuration but wanted the triple telescoping arms for FWD cars and the Ammco 2-N-1 was my choice which is the same as the Challenger you are looking at. Two of my co-workers also have the Challenger Versalift.
Nothing bad to say about the Rotary, just not as much experience with them as the Challenger/Ammco.
Mike
rattle_snake
Chandler, AZ
Given the slick marketing material out there for lifts, you should have trouble picking one. Most are very similar.
For cars only a asymmetrical, clear floor is probably best. You don't really need the 10k capacity for cars.
Note that I didn't recommend one or the other, but you would likely be happy with either. Once you use it a few times you will be so happy to have one the name on it won't matter.
brownbagg
which is best. rotary, what wrong with Challenger, nothing, they are both good lifts
BoostAddiction
Western North Carolina
I have a Rotary asymmetric 2-post and prefer it. It's easier to get in and out of the car when lifted, and the rubber trim on the posts is a nice touch to prevent damage to the car door. Make sure you get the clear-floor model as mentioned above, especially if you have a low car.
Either one would be a big upgrade compared to jacks and jack stands, though. :)
Todd.Brock
Cincinnati
I had a Nussbaum 2 post 8k Assymetric- It was handy for cars, but sort of sucked for trucks. My buddy had a symmetric Challenger 2 post. My Dodge Ram was easier to line up, but still a pain in the *** on his lift. I would say either lift is fine quality. Look at dealer support and parts availability
slimcake
I got a forward lift. 10k # rated asymmetrical. Made by rotary. Really like it so far. What is the problem with trucks and asymmetrical?
Aqua-Andy
The problem I have always had was that you can't get the truck forward enough to prevent the back end from sagging. 1/2 ton trucks you would be fine with the front pads flat and the rear pads with the small risers flipped up. 3/4 and 1 ton trucks I never liked lifting as the rear of the truck would be too bouncy. On the 9k LB Rotary I used a 1 ton ex cab dully was just unsafe.
