What is the top spindle speed on the South Bend? Being a clutchless machine, a high top spindle speed takes a lot of effort to start due to the inertia of the drive and spindle. I think the salesman is probably correct. I would follow his suggestion and go with a 7.5 HP converter. The only thing more expensive than an oversized converter is an undersized converter - you get to buy two converters then!
I start my 8,500lb 10HP American Pacemaker with a 10HP converter I built with an 1150 RPM motor and it starts fine. The Pacemaker is a clutched machine. I also run my Series II Bridgeport a 1HP Edlund High speed drill, and other machines on it. The Pacemaker comes up to speed in about 4 seconds, it seems.
I would buy or build more rotary converter than you currently need. You never know when another machine might come along which is bigger than your current machines.
I built my 10HP using the Fitch Williams design on Practical Machinist. His plans are in a sticky thread at the top of the "Phase Converters and VFD's" forum. The thread title is "Phase Converter Plans". My converter can be seen on the wall in a few photos in my bandsaw thread. They are not difficult to build if you understand basic electricity and industrial electric control. In fact, I learned a lot about 3-phase power and AC electricity building the project.
A few photos of mine:
The flexible conduit was a temporary "gotta see it run" setup.
In the not too distant future, I need to build a much larger converter. Probably 40-50HP. The design will be the same, just more capacitors!
You can get new soggy film capacitors, contactors, etc. from Surplus Center.com. I got almost everything from there. Only the Hoffman enclosure and Allen Bradley multi-purpose timer came from other sources. The motor was brand new, with the plastic and test report from Ebay. $200. Current retail price on the Reliance 10HP XT series 1150 RPM motor is $1,850. DON'T buy your motor from the factory. Buy it NOS!
