BirdMobile
- Joined
- Aug 16, 2014
- Messages
- 588
Construction is really simple. Take a T15 Torx driver, unscrew the flex joint. Finished.
You now have the smallest 3/8 stubby roto in existence! Enjoy!![]()
I bought my first roto ratchet 2 nights ago. Was out with the lady and grab one at HF to try out since I never owned one before. See what there story is.
Btw- is there away to lube a HF roto head ratchet? I don't see anyway to take it apart.
great trick! - and only costs $15 using the 25% coupon!
but it seems whenever I need a stubby that small I am usually using a 1/4" one already
Never saw the need for roto ratchets unless you happen to be a jungle-gym mechanic.
I used to feel the exact same way......until I started using one. Now it's my go to ratchet (hard handle long Snap-On roto head) They have so many advantages but they're one of those things that's difficult to explain, I'd have to show you or put one in your hand for a while.
I haven't found a way to disassemble them, but some posts here seem to say it's been done. I just soak the heads of mine in ATF to clean/lube them. Works OK... but the backdrag is pretty bad on HF's no matter what you do. When I bought my 4, I took all of them on the rack and turned them, compared and picked out the least "draggy" of the bunch.
Ha! - I do the same thing! - with every ratchet in every store!Works OK... but the backdrag is pretty bad on HF's no matter what you do. When I bought my 4, I took all of them on the rack and turned them, compared and picked out the least "draggy" of the bunch.
by far the worst of all my ratchets.Nice ratchets, but the backdrag is crazy highby far the worst of all my ratchets.
The 1/4" HF roto has twice as much backdrag as a 1/2" Wera Zyclop (also a roto!)
I have no idea what the original thing is for and I lego **** all the time. Still can't find out what the ez red double flex 1/4" ratchet is for. Doesn't make no sense to me; sure might be a place for it but you can't really use it normally because it's too floppy plus it's 1/4".
What I'm saying is...this is a slight upgrade I suppose.
I bought my first roto head ratchet at the flea market for $6.00 and it is a very nice S-K 3/8 long handle.
I am a Toolaholic,Sometimes I regret it,Especially when the Toolman wont give me no credit
