Roughness of floor for epoxy?
nate379
Palmer, AK
Wondering how rough the slab should be for epoxy?
I washed my floor several times to include hydrochloric acid etching. It was power toweled to begin with so nice and smooth.
It’s got a bit of texture to it now, but it’s not like a slab that was just bull floated or hand troweled.
I’m almost thinking of seeing if I can track down a slab grinder… but I don’t know really if I should spend the time and money with it… and even if it will do what I need?
Are you guys using the grinder to level out the floor or to rough it up?
Is there a good guide to how rough the slab should be?
N
nate379
Palmer, AK
I just went back a bit ago and put it down on a square (garage is cut into 4) at 100% right out of the jug and let it sit for 30 mins. It seems that it worked out nicely. Just have to go get more acid and do the rest I suppose... would have been easier to do that right from the get go! ARGHH!!!!!
I had mixed it 1 quart of the acid to about 3 quarts of water before. Followed the directions on the jug.
thegarageguy
Find a grinder rental with diamond inserts and a hepa vac. Acid is way too inconsistant and may result in future failure.
wildcat12
cookeville tennessee
it should be relative to thickness of the coating you are applying, the thicker the coating you are applying the more profile you need. I am guessing you are applying 10 mils or less so a profile like 80 to 120 grit sanpaper will be fine. Concrete has pores like your skin and you need to expose those pores so the coating will penerate to achieve a mechanical bond, so simply drop a little water on the concrete and see if it penatrates, or simply beads up
