mreisner
Glyphosate is not restricted use, so I wonder if it maybe had pursuit in it?
I use Dawn in every load I spray.Helps cut through waxy surfaces on plants and help dry powders dissolve better in hard water.
Anyone found a suitable (that works) substitute for RoundUp?
The 2 it contains are worse in my book. Diquat is nasty stuff, same family as Paraquat.
. . . both work fast and are very, very corrosive. They basically blow the plant cell walls apart, but do not move systemically in the plant so things like grass etc. Do grow back from the root mass.
Softer water can allow reduced active ingredient use by 30 percent or more.
What do you mean by corrosive? Corrosive to metal it might touch?
I've not noticed any issue with any plant growing back from the roots but the weeds do start dying the same day as you said.
One of the issues I had with RoundUp was in trying to control spurge. It took the RoundUp so long to work that the spurge would apparently drop seeds which would later germinate. I always had spurge coming up in the exact same spots. So, I switched to RoundUp's extended control product which was better on the spurge but it never worked as well as the Spectracide I'm using now.
Would love to find a safe alternative that works. I hate spraying chemicals but have yet to find a good substitute.
DC
Trimec is a good one.
Im not impressed with RU sprsy it on my driveway every year , grass grows back every year and us thicker than my lawn in some places. I gott see what my neighbor uses on his fence line, **** is always dead.
Sent from my SM-G920V using Tapatalk
Roundup has no residual action. You can spray it on the ground and toss down seeds which will the sprout.
