harleydog73
I am looking for parts for my Roush floor jack . the swivel at base of the handle is broken. my manual is in storage , don't know if it has a parts breakdown or not. Not having any luck on line
Hello Hiball,
I am at an impasse with my jack rebuild. I replaced the o-ring on the valve (small hole on top) and it began to work again, lifting my cars, but then I discovered another leak, coming out of the pump shaft. As you can see, I have it partially disassembled, but I cannot seem to get the large nut around the pump shaft to loosen, even a little bit.
1. what is the secret to loosening the pump shaft nut?
2. do I need special o-rings to finish the repair, if so, where can they be found?
3. any not-so-obvious things I should be aware of in the undertaking of this project?
Thanks in advance,
Len
