Router Bit Storage
metaldad
nw indiana
been recently adding to my collection of bits. been storing them either in the plastic cases they came in, or, in the plastic racks pistol ammo comes in (25 rounds). other than laying out and drilling 1/4 & 1/2 holes in a 2x, anyone have a better idea?
dwcon1431
The best advice I can give you is do whatever works best for you. Your storage options are obviously unique to you. This includes your budget. I would however, make sure the bits are kept separate from each other.
Sent from my SM-A102U using Tapatalk
tarmy
Nor Cal
I was re-arranging things when I took this. It is an extra Festool case that I bought foam for...
I have the foam block With 2 hole sizes in a grid, stashed in a cupboard. I still get a bit of rust on the shanks, but they don’t hit, or take up a ton of space as the factory boxes.
Similar to Tarmy, without the outer box
LeeG
Phoenix, AZ
I cut some 3/4” mdf into 1.5” and 3” squares. I drilled a hole in the middle of each, some 1/4” and some 1/2”. This lets me organize the bits in a drawer and not worry about them getting damaged.
View media item 108231
lilredex
Toronto
Here's what works for me..
cheechi
Triad, NC
one could even take this one step further and rout an edge (or multiple as may apply) with the profile of the bit being stored. I have found that helps organize in many cases especially with tall or very involved shaper bits.
Optionally if they were stored all in one place a piece of 1x stock routed with the profile and glued to the top can also be helpful. I like in some of them at least the option to pick it up and see (or show someone) the side profile of the end product.
Ohio Andy
Columbus, Ohio
I had intended to create drawers and then I bought foam that was already pre-drilled for them. But instead I just keep them in a festool pack out container designed specifically for bits
PCustoms
VT
Is storing the bits in drilled 2x6 lumber just asking for rust on the shanks?
Holy thread bump...
Mine live in a block of cherry. Or maybe maple. Either way no problems stored in the drawer of my router table in my (relatively) climate controlled shop
whitesco
Pittsburgh, PA (ish)
I inherited this little case from my grandfather. Brown plastic with a faux wood grain but no markings or logo anywhere that I can see. The bottom lifts out and there is space beneath for a couple of other small bits, I keep new unwrapped ones there.
Last one of those I saw was full of Craftsman bits without the depth of bite control. I set them down and eased away. It had a wood grain lamination in it.
whitesco
That tracks - Grandpa had loads of good ol’ Craftsman stuff. It’s a good case for me anyway, don’t do tons of router work and I don’t have a lot of really fancy bits.
tyyost
Tunkhannock, PA
I keep mine in the flat Plano fishing lure style boxes that are approximately 10x12. It is easier for me to see the profiles with them laying down, the seal up keeping sawdust and rust at bay, and I can stack them in a drawer. Bonus as they also work great for collets, wrenches, and other smaller router parts.
Outahere
Idaho
I keep mine in the flat Plano fishing lure style boxes that are approximately 10x12. .........
I like this type of storage. I went to the Plano website, and saw that their "StowAway" tackle trays have built in "corrosion resistant technology".
