Router suggestions?
signcrafter
I have about a dozen routers of all sizes. My biggest is an older PC plunge and my smallest is a PC compact router with many in the middle. Each one has it's own use. I use the compact router all the time for free hand work. It's lite and moves easy and has power to do most things. I use my PC 2.25HP kit(fixed base and plunge base) for jobs that require a little more power. Also have an older dewalt medium sized router that is a beast for it's size. Then one for my router table. Then the big boys for when I need serious power. It all depends on what you plan on using them for. You just said woodworking but that is kind of vague. If you just want to round over an edge then a small router will be fine. If you want to take big chunks of wood out then you will need a big router.
Depending on what exactly you are doing the best bang for your buck is going to be a kit that comes with a fixed base and a plunge base and one motor. A nice 2.25HP router will be powerful enough to run most bits but still small enough to do most detail work.
Also routers are addicting. Once you start using them and buying different bits you will end up putting edges on all sorts of things and making jigs to do some neat stuff with your routers. Also buy decent bits, these are also addicting and can add up to well over the cost of the router very quickly!
Lastly, make sure you read up on safety. Things like which direction to run them for doing different jobs. They aren't crazy dangerous but they are a blade spinning at 20,000 RPMs so they deserve some respect. Another tip is I go through a bunch of that cheap non slip kitchen drawer liner. It works great to set a board on and do your routing.
Slupie
Bartlett, IL
Another vote for Porter Cable, I have one 693 kit, one 690 and one 890, use them all and would not use anything else after owning few other other brands. Bosch Colt is another one but it is for light duty jobs.
CNGsaves
KS and OK
When you have a little time to kill watch this video good info and tips for routing in general.
^ ^ Good info by Bosch rep (around an hour long).
Below are some general router videos by Norm Abram when he was making New Yankee Workshop. Now he's contributor on This Old House.
Routers 101 Complete Guide - - - Part 1 of 2
Routers 101 Complete Guide - - - Part 2 of 2
General info about using routers including bits, plunge cuts, mortis cuts, router table, raised-panel door, dutchman repair, template cutting, etc.
BellyUpFish
Alabama
Good reply..
I've got a small Craftsman in a table I picked up earlier this year for next to nothing I've been using. I'm planning on recessing the table into my Ridgid 4512, but would like to also pick up a hand unit.
You're dead on about safety. I about got my finger into the blade when I was a kid using a table. Scared me to death..
Bluebeard
For home/hobby use and my first router I went with a Skill and am happy with it so far.
http://www.amazon.com/gp/aw/d/B004SKY73O/ref=redir_mdp_mobile?ref_=pe_385040_30332190_TE_dp_1
It came with both bases and although I really wanted a PC or one of the higher quality models, I knew for the amount I would use the tool I couldn't justify the cost and needed other tools. I ended up picking up a HF 10" sliding miter saw and still spent less and that saw has already paid for itself on my recent home floor install.
brass89
Going through a similar search myself and came across a tool review for the hitachi 12 amp. Was considering it because they had a combo kit for like $150 or so refurbed and people raved how quiet it was. The tool review made me reconsider though. Maybe it was just a dud unit, but the incremental plunge adjuster on the base was so sloppy it wouldn't hold position (no positive indents or anything). They said it had a habit of spinning around under vibration and if it spun too far, your next plunge may accidentally go deeper than intended. Also, the guy doing the review pointed out that the plunge had a habit of getting stuck and wouldn't smoothly release. He had to tap the edge of the base and shake/jerk it a couple times to get to come back up. Not something you wanna do exiting a plunge cut. I have nothing against hitachi, just something to consider. Like I said, maybe he had the odd case but his issues he was able to reproduce with consistency.
Here's the link to the hitachi 12kmv (11amp) review I was referring to.
BellyUpFish
Alabama
I think I may go with the Bosch, but haven't ordered anything yet. Spent all day dreaming about a CNC mill. Lol
