boilermanc
I read through several of the threads on this but did not find exactly what I was looking for. I just purchased the pipe setup for dust collection system. I am mounting it behind the wall where the tools are. It has hoses that connect the pipe to the tool. I will be running the pipe up and out through the attic to a lean to against the house where I will run the vacuum.
My question is, should the pipe be mounted low on the wall just above the tools or high on the wall along the ceiling with just the hoses coming down to the tools? I didn't think it mattered but then I found some videos and with all this information about suction levels, humidity, distance, angles etc. You can see it here. This is pretty... technical!
It all made sense that that would matter but wow, it was alot to try to figure out. So just starting with what I hope is a basic question.
thanks!
thanks!
