Im planning on installing a dual zone mini split system and would like to know the best way route for the the line set for the second zone which is on the opposite side of the house. Here are my thoughts for routing the line set:
1. From the condenser, through the attic, secure along the attic rafters then out the opposite side of the house and then return the line set back into the house to the air handler.
2. From the condenser, into the basement, secure line set the the floor joists then out the opposite side of the house and then up the far wall and then back in.
I cannot run the line-set in the far wall because the 2x8 floor joists prevent drilling a hole from both the basement to the first floor and from the first floor to the attic. If the air handler was on the front or the back of the house this would’ve been possible because I could have drill in between the 2x8 but that would look aesthetically pleasing. Any advice would be much appreciated.
