Rubber blocks for lift
rburke65
Canfield, Ohio
You might want to check on McMasters. I am sure they have cushions of under machinery, compressors and the like.
gscallon
Google "Jeweler Bench Block". That's what I use. Cheap, strong and just a tad bit flexible.
-Greg
astroracer
Mid_Michigan
What are you using the rubber blocks for? I use a lot of cut off 2 x 4's and such to "adapt" chassis's and vehicles to the lift but never rubber. If you are doing this I hope you use a very hard durometer so the rubber doesn't settle and let the load shift.
Mark
zollster
USA
I use cut offs from rubber live-stock mat that is sold at TSC. about 3/4" thick. Fills the gap.
rslaback
Westcentral Wisconsin
I used cut down wheel chocks on my mid rise. I used these and cut them off at the 3rd section with a bandsaw.
zollster
USA
Live-stock mat from TSC
racerex
NY
Vibration isolation pads that are used under mechanical equipment (i.e., pumps, fans, etc.). My father had a commercial/industrial HVAC business for 35+ plus years and they kept a small inventory of them in different sizes and load ratings in the supply room at his fab shop. I would do a little "shopping" in the supply room every now and then. I have them in a bunch of different sizes and thickness.
I can't remember the name of the supply house that they got them from, but Grainger has them....just search "vibration isolation pads"
T
Twincam.22
thanks for all suggestions lads should be well able to put something together with all ideas here...
Falcon67
Merkel, TX
This is what I'd use - very dense. Used under my air compressor. Lots of uses. Some pieces used to keep the washing machine from walking through the laundry room wall (tile floor). Cuts with a sharp box cutter, nothing much else will hurt it.
No hockey pucks in this part of Texas. None at Dicks in Fort Worth either - I looked.
ovilla
Plainfield, IL
So does BendPak! Just call them and let them know what sizes you need. They have a nice assortment of sizes that come with the QuickJack.
