Phatsub
Who's got rubber feet on their compressor and where did you get them?
Pictures are always appreciated.
take a short trip down your nearest interstate or major highway ... look along the side of the road for a blown semi tire ... take it home and cut yourself some CHEAP pads with your jig saw
There are various sorts of machinery feet available from MSC, Grainger, McMaster-Carr, etc. I used some from MSC that are fairly inexpensive, made by Mason.
http://www1.mscdirect.com/CGI/NNSRIT?PMPXNO=5368263&PMT4NO=25146218
My compressor is on a stand that has six legs with a four foot spread, to add stability to a rather top heavy compressor (vertical 80 gal two stage, 7.5 hp).
Here is a link to a pic from a previous post. I cannot reattach the pic without re-uploading it (duh!) so I won't waste the server space to do that.
http://www.garagejournal.com/forum/attachment.php?attachmentid=4246&d=1137985390
Charles
Charles,
The feet on your 6 legged base, are they the same as the feet in your first link from MSC Direct? Those are exactly what I'm looking for. Thanks for the info.
I mounted my 6.5hp 60-gallon on automotive body mount cushions; it's in a corner, with a safety cable from the compressor mount plate to an eyebolt in a stud on each wall. Hasn't moved a millimeter in seven years.![]()
whats wrong with hockey pucks?
John,
Those cushions are from which model truck?
I asked the same question from his garage post.....no reply.
I would also like to know. I'm in the same boat. I'm thinking a trip to the junkyard next week to see if I can locate anything....
I'm sure he's said it before...at least I think he has. I will search...
Probably just about any truck mount will do.
If you find it, PM me the link
Thanks
The man asked about rubber feet, implying he wanted some cushion under his compressor.
Charles
Well, last night I ordered three of these...The -40's.
http://www.vibrationmounts.com/Store.asp?Page=Products3.htm
Hopefully they'll be robust enough.
Here's the PN. V10Z76MSG-40 The link above doesn't take you right to them.
Use the rubber engine cradle mounts from any GM front wheel drive vehicle.
I used hockey pucks. They are a very hard rubber, but perfect for the weight of a heavy compressor...
I just left mine bolted to the shipping pallet it came on. Flexible enough. And it hasn't moved in 3 years even though the compressor runs every day. I figure if I ever need to move it, I can just use a hand pallet truck.
Dale
