Rubber pads for Jack and stands?
Lewisthepilgrim
seacoast NH
It has recently occurred to me my method of jacking up my automobiles is sub par. I would like to add a rubber pad to my Jack and Jack stands. I have 5 ton stands, and the big harbor freight Jack (goes up to 24")
What are some good rubber pads I can use?
What do you guys use to protect your car from the metal on metal contact??
I always use a 4x6 block of wood on the jack pad. I cut a big groove in it so I can lift on the weld seam under the rocker panels.
nafterclifen
Poconos, PA
How about a horse stall mat? They're usually 3/4" rubber and for about $40, you get a 4'x6' sheet that you could cut up and use for a variety of different things - jack stand pads, floor jack pads, kneeling pads, etc.
unslow1
Illinois
I work on lots of show cars and usually I use those HF style ones. Some I have old towels taped around.
APEowner
Sunny, New Mexico
I work on mostly race cars, pickup trucks and race cars so I don't worry about scratches from jacks and jack stands but when I was working on show cars and restorations I used towels.
L
Lewisthepilgrim
seacoast NH
Awesome info thanks guys. I actually have an old thick rubber piece of Mat from a van(about an inch thick) I think I will cut some pieces out and glue them onto the Jack and stands! Thanks for the idea!
dacan23
RI
Hockey puck on the jack but you have to get the good ones made in Czech Republic I think.
Chilliwack Murray
Chilliwack BC
If it's a flat surface always use a piece of wood so it doesn't slip off but depending on the weight you support you may need a metal plate between the jack and the wood to spread the load or the wood will crush. I have a few old rubber block suspension blocks that I use if I need to support an engine etc and when I don't want to mark something but the slotted jack pads in the link are great - haven't seen those before.
I have flat top and saddle type jack stands - both home made, never thought about something on top of the saddle top though.
I have one new enough vehicle to have these lift points and have so far just used the rubber blocks to spread the weight over a longer distance... will be ordering some of those slotted adapters shortly for the lift.
unslow1
Illinois
Once thought the reviews said those HF jack stand covers don't fit right :headscrat
I have several jack stands. They fit some perfectly. Others ones they don't fit well. You will have to try them on a set to see.
DFB
Southern VT/Western Mass
Thanks I always been wondering about them.
I've owned two sets of the 6 ton jackstands forever (among some other smaller ones) their not Frieghts though. Speedway series is what they are and for all purposes they seem to be the same configuration
tomwil
