Rubbermaid yard trailer
usmc_noma
virginia
If you don't care if it's metal, there was one at the Sears outlet for $90. Basically the same as the big box store Agrifab ones.
bas157
Near Philly
This one is nice for abunch of reasons, the walls come off to make loading and unloading heavy things easier, stores easily and won't take up much space if you break it down, and it won't rust. It was looking for one of these but ended up with a convertible tractor cart .... Can be towed behind the lawn tractor or used liked a large wheelbarrow by flipping the tongue in half up under the cart.
TreePointer
PA
NOTE: These are NOT the same poly carts at the big box stores. These are made from structural foam plastic and do not flex. Our 10 cu.ft. Rubbermaid cart has taken a beating (firewood, dirt, mulch, stones, grass, hay) for 15 years and doesn't even have a chip out of it. It's much lighter than an all steel model and the lift gate makes dumping the entire load easy.
Rubbermaid® Lawn Tractor Cart Trailer 10 Cu. Ft. Capacity
It's the best lawn tractor cart I've ever had. Worth every penny.
T
TejasBimmer
off I-35, TEXAS!
Exactly tree pointer, I wanted this, because, it will be used with wet ****, dirt, rocks etc.... I do not want to worry about chipping paint, cracked thin walled plastic.
Structural foam plastic is better suited for the yard jobs I plan to do.
I just hope I do not regret not getting the 10 cu-ft version.... :)
