BTL-A4
The triangular scales are not steel, but plastic. Over time they get worn. The metal sleeve on a mechanical pencil will cause wear, as does the lead when the edge is used as a straight edge.
Everything is a hammer.Sounds almost as bad as using a screwdriver as a chisel...
Or a pipe wrench as a hammer...
Except micrometers. They're C clamps.Everything is a hammer.
The old vernier calipers can be used as a thin wrench, not successfully though.Except micrometers. They're C clamps.
The reference is not to steel scales. It was about triangular scales. They were always wood or plastic. The tic marks go right down to a sharp edge.Hmmm...even my professors were doing it 'wrong' then as well. Oh well....I'm neither an architect or an engineer these days, so cannuck got his wish!
Everything turned to Solidworks and CAD these days anyways (had those classes too).
So how does a soft pencil do damage to a stainless steel scale? Not wanting to argue, but if my teachers & professors didn't know (or just didn't care), then I'd like to learn why...
I received the ruler.You guys ever hear of Woodrow Engineering Co scales/rulers?
https://www.woodrowrulers.com
I pulled the trigger on one from Amazon. Four scale and joist.
It didn’t check all my boxes, but I feel it will be useful and I might supplement it with another basic ruler with inch and metric scales. Their brass and walnut ruler caught my eye too. We will see how it performs. If it’s decent, I’ll post a picture back here.
For those too young to realize what you are talking about: the "cork back" and "reveal" are what raised the edge of a rule off of the paper - because we did our original design stuff with mechanical pencils on paper but your permanent drawings were done on vellum with pen and ink (i.e. NO possibility of correcting a mistake). If you put ink down on the rule it would wick under the surface due to capilliary effect and make your perfectly clean/sharp line into a straight side away from the rule but a ragged edge underneath. Solution is to raise the edge of the rule above surface with a layer of cork or machine the edge underneath (relieve it) to keep it away from the contact surface of the pen. THAT is why you never try to measure with a rule (parallax error) unless you turn it 90 degrees for the lines to touch down on the paper. THAT is also why you don't draw with a scale - as the sharp end of the mechanical pencil will wear the edge and an ink pen would make a horrible mess of the scale and the drawing. Also, the steel part of the pencil will bear against the raised edge of the rule but on a scale it may or may not - giving inconsistent offset of line from straightedge.I received the ruler.
Initial impressions are decent. Its a little more fragile than id like, but time will tell how it holds up.
The combination of wood and plastic makes for a quality feel.
The lacquer and markings are finished well.
I was happy to see a leading edge reveal similar to cork back which you can see in the pic below.
Im still looking at other options some mentioned for a basic ruler.
Thanks for all the suggestions and banter.
season so why not go overboard a lil?
I am an engineer, admittedly not at the same level as your friend, but I am convinced our brains just plan work differently. When I was in school it was all CAD so didn't get much on the hand drawing side but being able to look at a 2D drawing and be able to visualize it in a 3D space is a skill that goes a long way in the engineering world. Piping Isometrics can really twist your brain in knots when you are trying to compare what is on paper to what is being built.For those too young to realize what you are talking about: the "cork back" and "reveal" are what raised the edge of a rule off of the paper - because we did our original design stuff with mechanical pencils on paper but your permanent drawings were done on vellum with pen and ink (i.e. NO possibility of correcting a mistake). If you put ink down on the rule it would wick under the surface due to capilliary effect and make your perfectly clean/sharp line into a straight side away from the rule but a ragged edge underneath. Solution is to raise the edge of the rule above surface with a layer of cork or machine the edge underneath (relieve it) to keep it away from the contact surface of the pen. THAT is why you never try to measure with a rule (parallax error) unless you turn it 90 degrees for the lines to touch down on the paper. THAT is also why you don't draw with a scale - as the sharp end of the mechanical pencil will wear the edge and an ink pen would make a horrible mess of the scale and the drawing. Also, the steel part of the pencil will bear against the raised edge of the rule but on a scale it may or may not - giving inconsistent offset of line from straightedge.
Just to show you where the art of engineering once was: I have a friend I consider THE most capable engineer I have ever met (has designed and built 12 airplanes with his own hands in a log cabin in remote bush - not to mention his actual work accomplishments). I first met him 48 years ago when I was at a mine and shown an ink drawing obviously using a lettering template of something they wanted built. I made some kind of comment how wasteful it must be to have a draftsman turn and engineer's sketch into a formal pen-and-ink drawing for what was just a brainstorming session. I was told that it WAS a freehand sketch done by one of their engineers who had recently emigrated from Sweden. To this day I believe the design process works SO much better on the board instead of from a CAD programme because the person doing the drawing must solve so many of the design issues in 3 dimensions in his mind to MAKE the drawing in the fist place. My Swedish engineer buddy is one of the best examples I can imagine.
Incra makes rules with holes and slots for 0.5mm pencils in all sorts of sizes and configurations. I find their 12" Tee rule to be indispensable when drilling cabinet hardware for example:...I know OP already picked out a ruler but I wanted to throw these out there as well. The General 641. I think I saw them posted in the new tool thread and decided to pick up a couple. They are only 6" but I like the holes for marking and they seem to be very accurate. Fairly flexible too.
General No. 641 6" Stainless Steel Flexible Marking Rule & Pencil. Made in USA 38728321121 | eBay
Find many great new & used options and get the best deals for General No. 641 6" Stainless Steel Flexible Marking Rule & Pencil. Made in USA at the best online prices at eBay! Free shipping for many products!www.ebay.com
