Running 100amp Service to Detached Shop
ml504
Like the title says I'm running service to my shop from my existing 200amp panel in my house. I'll be running 4 #3 wires (copper) in conduit all the way and it will be buried. Two questions:
1. The conduit with the new wire will cross over the existing direct burial wire that feeds my main 200amp service. Is it ok that they will be close to one another (not touching though obviously)?
2. For conduit size, is 1.5" sufficient or should I run 2"?
Thanks,
Matt
ml504
Anyone have advice on crossing wire paths undergound? I can't find anything that says not too, just would like some extra input. Thanks...
Aceman
Eastern Oregon
You don't need four #3's, you only need three, with a #8 green.
Should be fine. God help you though if you hit the power co. wires.....
It'd fit in an 1.25" easily, if you want to go larger you certainly can.
