Hi, I found these forums through a completely unrelated google search, however I figured it would probably be the best place to get decent answers to an idea I've had for a while. Apologies if this post is a bit long winded, but given the application I want to use it for is probably unfamiliar to most of you, I want to make as clear of a picture as possible.
I do a fair bit of amateur/home chemistry, and as such, have been looking around for a decent way to rig up a vacuum apparatus for distillations(usually pretty standard, yet extremely expensive lab vac pumps are used.)
I own a 2.5hp 40l air compressor that is rarely used these days. The intake filter is threaded, and recently I came across a fitting for a drain cleaner which was the exact same sizing, and terminated in a barb that also happened to be the same size as my vacuum adapter(http://www.erowid.org/archive/rhodium/chemistry/equipment/pictures/zubrick098.gif
first google images result that gives an accurate depiction, far right of the pic.)
Given this, is there any particular reason why it would be unwise to use it as a vacuum pump? I can use an inline filter to prevent any nasties from getting into the compressor but I'm not sure if there are any other potential hazards here. Any input would be appreciated.
