Running capacitor for motor
happymachinist
Central NE
So the running capacitor on a spare motor I have is shot. I had a hard time finding one the right physical size and correct uF. I found a cheap one on amazon that was close enough in size and required 60uF.
Upon arrival I measured it with my fluke meter and it reads at 81uF!! I understand the tolerance for most capacitors is +/- 6% and understand the capacitor I received is way out of spec...thanks China. I am assuming the spec motors are made to are also in the +/-6% range also.
What would the issues be in running this capacitor? I might try to find another capacitor again but this is just a spare cheapo Taiwanese motor and don't want to dump a bunch of money in it.
Is it dangerous to run this capacitor, will it just lead to diminished motor life or excess heat? Any input would be appreciated.
Thanks
Bert_
NW Iowa
Thanks
I'm guessing it would be ok. It will cause some extra current through the start winding. Probably not enough to cause problems. But that's just a guess.
Have you checked any other caps to verify meter function?
6PTsocket
Thanks
The tolerance on motor capacitors is very broad, probably more like 20%. Don't give it a second thought. Use it. Just don't ever use a start cap for a run cap, even if the value is correct. They are not meant for contiuous duty and it will fail very quickly. Many motor caps are listed with a range of values on them rather than a tolerance.
H
happymachinist
Central NE
Awesome! Thanks for the input like I said it’s a cheap (free) used motor and if its longevity goes down a bit I’m not out much.
American Locomotive
Rhode Island
The tolerance on electrolytic start capacitors is pretty large, usually around 20% or so. However the tolerance on run capacitors is typically much tighter.
81uF vs 60 is +35%, which is huge. I would expect the motor to run a lot hotter, and consume more power.
