ratdoggy
I need to run electric out to a pergola and the best way to run it would be under a sidewalk. What's the easiest way to tunnel under it? Should I put PVC under it as I'm intending to use direct burial cable.
Yes. This works like a charm. I glue a pvc cap on the end and drill a few holes in it for the nozzle.You can tunnel under a sidewalk pretty easily using a garden hose attached to a PVC pipe and jet nozzle. Digging the holes on either side of the sidewalk would take longer than the water drilling.
