X53Gunner
Ok, going to try and explain my question.
I have two buildings one storage and the other is my shop for reference.
I'm going to put my stand up compressor in the storage building that is 120' away from my shop and plum an airline underground between the two. I'm running a 1/2" pressurized pipe between the two buildings. This pressurized pipe is also in a 2" PVC pipe just for some protection. I'm not worried about any code issue I just want to know what will and will not work. If I"m thinking correctly, If I have 125 PSI at my stand up compressor in the storage building then in theory I should have 125 PSI in my shop via the 1/2" pipe. (i could be wrong) However do I loose volume in any way by constricting it to the 1/2" pipe while using Impact wrenches and such? The thing i'm wondering is if I'm using a impact wrench or larger air tool, for the air to keep up with the initial drop in air from using the tool, do you think I should run the 1/2" pipe into a separate 11 gallon air tank in my work shop to keep the volume going? I know it can't hurt just wondered if its necessary? Sorry for such a long winded question. Please let me know your thoughts on this if you have experience with running longer airlines before. Thanks so much for the help guys!
Scott
Scott
