Running MaxJax hyd lines along floor?
cwraab
Just installed a MaxJax and am looking for a clean way to mount my pump and run the lines since I have no intentions of moving the MaxJax. I see folks who run the lines across the ceiling and then down to the column but has anybody routed their lines on the floor?
I'm considering a heavy duty cable/tube guard like this.
http://www.cabletiesandmore.com/CTAM-heavy-duty-rubber-cable-protectors.php
It appears to be rated for any vehicles I'd be driving over it. Any thoughts?
Spareparts
Lansing Ks.
They make a spiral wrap specifically for hyd hoses, very, very durable and not to pricy, I have also used inverted C-Channel with some tabs to anchor it to the floor. You can get the wrap from any hyd shop that makes hoses.
plow
Louisiana
Maybe rent a concrete saw and cut a few grooves then knock it out with a hammer?????
