TonyJ
Question for you air compressor gurus out there. I have two compressors which both work great and both are old. One is a Quincy 230 rc28 that is mounted to a 80gal tank. I also have a Ingersol Rand type 30 242 D3 which is mounted to a 30gal tank. Quincy specs is 100psi and I’m currently running it @ 150psi and the IR specs is 230psi but tank max is only 200 so I have it setting at 195psi.
95 % of the work I do the Quincy handles it just fine but the other 5% I’m having to wait for the air to build back up and then I allot of times still have to break out the IR for the higher psi.
Would it be just all around smarter for me to just connect the two tanks and put a valve between them and just let the IR build up the psi in both tanks for those needed times and just use the Quincy at a lower psi for the 95% of the time the higher psi isn’t needed ? Hooking the two together would greatly increase the storage of 195psi air when needed and would be lowered back to normal in the 80 when it isn’t needed is the idea I have
