Hey All-
I am looking for some information regarding running electric for my 24x50 metal building that was just erected. The building is roughly 50' from the house and has a J-pipe and ground stake in place at the corner of the foundation.
I would like to run all the outlets and lights myself and then have someone come in to run the power from the house to the garage. I plan on using conduit tubing for all of it.
My questions are as follows:
-Will someone run the wire from the house to the garage and hook up the circuit breaker if I did all the other work?
-I am having trouble finding clarification on mounting the receptacle boxes. Is there a minimum distance I must maintain from the outer wall?
-Is there a good way of running the conduit around each of the vertical supports as I run horizontally down the garage? I am guessing just bend the conduit around the supports?
-I do not plan on drywalling the garage but might put plywood over the metal supports to mount some cabinets, peg board, etc.. Do I need to do anything special if I am running conduit behind the wood?
Thanks!
Thanks!
