FarmerSid
Hey all! Glad I found this site. Talk about info overload. Been searching this site for info for the past 3 or 4 days. Looking for some advice suggestions on running power to a 36'X72' horse barn shop combo. It is going to be 130' from the house. I currently have a 200A service in my house and want to run 100A to the new barn shop combo. My house has electric base board heaters but they have all been removed. I heat the house with wood/oil forced air furnace and have an oil fired hot water heater. The oil furnace is a back-up as I heat with wood 100% of the time. I have 2 fridges and 1 full sized freezer and dishwasher. No AC.
The building is going to be built on the west end of the house. My panel is on the east end of the house so I will have to run about 70' of 100A wire inside the house and then 130' of 100A wire underground to the shop. I have only 16"-20" of soil till I hit limestone. I have called several electrical suppliers to find out what I need but none will tell me what I need. or how to do it. Only hints. I priced NW #2 3 wire @ $25.77 per m CDN for the 130' run and ND#3 3 wire @ $17.32 per m CDN for the 70' inside run. Way more $ than I expected. The best info I have been told I can do is run #2 aluminum which is $7.55 per m CDN.
I'm not sure if I can run this inside the house as well as underground. I also plan on running water, phone and network wireing in the same trench. Any suggestions on what I should do? Since I only have 16"-20" of soil, how do I install a ground rod at the new building? I am going to be installing a 7 HP air compressor, 2 post 800 LB lift and Millermatic 251 MIG welder as well as lights and 110 plugs with a 1500W tank heater.
Also, can I run Teck cable inside the house to where it will exit the house? I have about 100' of #2 teck but not enough to go to the shop.
Thanks to all that can share their knowledge and hopefully someone familiar with the Canadian electrical code will share some of their knowledge.
Cheers!
Sid
Cheers!
Sid
