5mall5nail5
Hi all - I am moving a computer rack down into my basement. Currently draws 3.0A on 120v and I don't plan to draw much more - maybe 5A. I was going to run two 20A 120V circuits from a subpanel we have in our addition since it has crawlspace access.
I've wired many circuits before but never to cement walls/basement. I am thinking I should run EMT or PVC. I should run THHN/THWN through the conduit as well, not NM-B, yah? It'd be a straight shot down the conduit, but not sure whether NM-B is allowed in conduit by code.
That said, because the circuit will be coming into the basement above the foundation how does one properly go from NM-B (that'll run along the joists) to the EMT? Do I do just do a junction box at the top of the EMT and transition from NM-B to THHN/THWN in there?
Also, was defines a "wet location"? I am installing this in a basement and although its "dry" the sump holds water and there is a gap around the floating slab that will have usually have about 1/2 - 1" of water in it. Never had water on the floor surface, but curious.
Thanks all.
Thanks all.
