I am finally starting the electrical in my garage. I have a 40 space sub panel that will be mounted in a 2x4 wall. I would like to run as much of the wiring as I can out the bottom of the panel so the top stays open for easier access in the future if a circuit needs to be added. My plan is to come out the bottom of the panel with the wires, go through holes in the studs, and run the wiring up in the bays next to the panel. I know the code says all wiring needs to be 1 1/4" away from the face of the stud, so that only leaves me 1" of 2x4 left to attach the wires. I bought a bag of the 3M stackers, which will allow 4 12-2 wires to be run on the side of 1 stud, but I have a lot more wires then I have room for. Right now it looks like I will have 14 20 amp 115 volt circuits, 9 50 amp 220 circuits that will use 6/3 wire, and 2 30 amp 220 circuits that will use 10/3 wire. On the 6/3, it looks like I can only have 1 wire attached to the side of a 2x4 and still keep the 1 1/4" space to the faces of the stud. Is there anything similar to the 3M stackers that will work on the 6/3 wire? How about something that would go across the whole width between the studs which would allow multiple wires to be run? Any advice would be greatly appreciated.
