Is that 160 PSI measured at the tool, with the tool running? You have to connect a pressure guage at the tool in order to check the working pressure.
I wondered about the pressures too. But the more I have looked at shops, asked around, and learned about engineering. Most things are engineered and tested to be safe at 2-3 times the "normal" specs. So if a tool is designed and tested to use at 100psi then why can't it run at 150-175 when it should easily be capable of 200+ psi
..which in short says: Most manufacturers of 1/2-inch impact wrenches rate their tool's power at 90 psi.This means that given an adequate volume of air at 90 psi the impact wrench will develop its full rated torque.
And just for another point of reference:
http://www.engineeringtoolbox.com/air-consumption-tools-d_847.html
...which also states:
The air consumption is based on a common working pressure of approximately 90 psi (620 kPa, 6.2 bar).
Your compressor and your tools will thank you for running a lower pressure.
