Running water line after the fact
xsethelsenx
WA
I put up a 30x40 metal garage a couple of years ago. Unexpectedly this summer, I ended up drilling a second water well nearby, that will feed into a large cistern up the hill.
Trying to figure out the best way to run the water line. I will have a waterline into the pressure tank from the well, and another running from the tank up to the cistern. Is there a good way to protect the water line from freezing without having to drill into my concrete slab? Thanks!
mike93lx
Richmond, VA
If you don't get it into a heated space when above the frost line, you will be limited to using something like heat tape
Shiftless
East Bay SFO
I assume you absolutely have to cross over the driveway. Is that so?
As Mike just said, heat tape (and foam pipe insulation) will keep the pipe from freezing.
X
xsethelsenx
WA
Thanks. In western WA. Don't often get long freezes, but just high enough in the hills that it does get cold sometimes.
