robertearl
Ok I am going to run the wires for my sub panel in the new shop from the house. To get to the shop I will have to run the wires from one end of the house to the other and then down and buried to the shop. The length will be about 110'.
In the attic, there will have to be multiple bends in the PVC to get it to the other side of the house. How do you actually run the wire through the PVC?
1. Do you pull them through one at a time and then cut to the correct length?
2. Do you pull something through that you can measure and cut all of the wires to that length and then pull them all through at once?
3. Do you glue the PVC together or do you leave each piece separate until you get the wire through and then go back and glue it?
4. When you are coming down the outside wall to get to the main panel, do you just cut out a large hole in the sheet rock so that you have room to work and then go back and patch the wall or is there a neat trick to do this that I do not know about?
5. I am going to put in a 100 amp subpanel. I believe that the max I would really see is 60 amps. Would #4 copper be OK for this?
6. What size PVC? 1 1/2" or 2"
Reb
Reb
