CarCrazyRDM
I'm currently wiring up my 24x36 detached garage. I have an 8' x 12' lean to on the back of the building that I want to put a light in/under. There are probably many ways to do this so I am open to hearing all suggestions but ultimately I just want it to look clean and meet code.
Can I simply just drill a hole in the back wall for the wire to pass through and then seal it up? Or do I need a box on the inside of the wall and then pass through the back of it and out? Or some other method?
Once the wire passes outside is it required to be in conduit up to the light fixture?
If it matters I plan to mount the light on the bottom of the joists and not to the back wall.
Thanks for any input,
Ryan
Here is the outside:
And the inside...
Ryan
And the inside...
