Nitpicker
In the process of budgeting. I need to run wire for 240 to a detached garage. The distance is 88 ft outside of the buildings. the detached garage has a sub panel box already installed. I'm in South Western PA frost line is four feet. Called for cost of wire to run a compressor, plasma cutter and welder. Welder is speced at 180 amp, the plasma at 25-45 amp. and the compressor at 32 amp. I was told that what I require is UF 6/3.
I asked about conduit and was told it was necessary -- even though the wire is stated for underground.
Here's what I need for information/confirmation
1. What size conduit?
2. Can I run three additional 12/3 wires for lights and work bench, door openers as well as the 6/3 in the same conduit at the same time?
3. How deep to bury the conduit?
4. What kind of conduit Schedule 40, 80, metal?
5. How much additional slack wire is required for connection directly opposite to the 200amp house box and connection to the sub panel once through the walls?
6. Electric supplier will cut to length at $2.50/ft. That is close with other local suppliers -- but is that reasonable?
7. What am I missing or what else do I need to ask?
