FarmerPete
So, I am planning on outfitting my garage to some extent, and I decided I should check on the wiring situation. Long story short, it's not good. It looks like the garage has a single 15a fuse that it shares with 3-4 light fixtures in the house.
Currently I just have two Edison lights, a garage door opener, and two plugs in the garage. I'd like to add 2 or 4 T8 fixtures in the garage. I also would like to add 2-4 additional outlets. I'd like to have a little bit of overhead in case I want to run a compressor or a 110 welder in the future (I don't have either currently).
I took a look at my fuse box, and unless I'm mistaken, I'm running very underpowered. So my house has a main fuse panel in the basement (100a & full). Since the house was built, they added a ~600 sq ft addition. Later, they added a sunroom with a hot tub. They put in a second 60a breaker box for the sunroom in the basement near the sunroom. I've removed the hot tub, and there is very little currently running off of my secondary box. Just some outlets in the basement where the previous owner had a workshop, and there is an empty 220 plug that looks like they had plans to hook up a generator to it.
My question would be this, what do you think would be advisable? The way I see it, I have two options that don't involve replacing my main box. I could run two 20a lines to the garage with 2 or 3 outlets on each. Or could I run a line from my secondary breaker box to my garage and put in a third box inside the garage? Would there be any benefit to that? In theory, I could use beefy wire so that if I ever did upgrade my panels in the basement, I could up the amperage in the garage as well? Thoughts?
