glentre
I painted my new garage concrete floor with Rust Bullet 20 months ago. Three coats of base and two of clear topcoat. It looked beautiful when it was done. About a month or so later, I started seeing dark spots in the paint. These blotches continued to grow in size all over the floor as can be seen in the photo. I'm not sure if the blotches are done spreading or if the floor is stabilized after 20 months.
I suspect my floor was not dry enough when the paint was applied and this caused the blotches since Rust Bullet is a moisture cure product. My bad on that point and I now realize I should have waited longer to apply the coating.
I am looking for some advice on what coating I can use to repaint the floor and what prep work would be required to do it. Need something that will adhere and bond with the Rust Bullet and not just lay on top of the original coating.
If anyone can help with this problem, please give me some ideas.
Glen
Glen
