OzJustin
Hi all
New member here and seeking some advice on Rust Bullet application.
I have a two car garage shed (approx 40m2 or 430ft2) with a concrete slab floor with a previous coating (looks like a grey paving paint that has worn under sunlight, hot tyre pickup etc) that has worn away. I suspect I will need to diamond grind the slab to remove the existing coating and then there are a few rust and oil spots and a couple of cracks that I will need to fill and smooth over before I can think about applying a coating.
I was originally set on applying the Legacy Industrial Nohr-S coating but unfortunately that product is not available in Australia.
This leads me to my backup option, Rust Bullet, which is available in Australia. When I contacted the distributor I got the impression they don't stock the 'concrete' version of Rust Bullet though and were recommending the Industrial/Automotive versions for concrete.
Can I get users' thoughts on applying one coat of the Rust Bullet Gold Industrial and then a second coat of the WhiteShell colorshot with a slip additive mixed in. I gather I will need approx 1 gallon or a little more per coat for my intended floor area. Will this Industrial version provide similar performance to the 'concrete' specific blend? I want a strong bond, UV stable, high gloss etc.
Thoughts on my intended path based on what is available to me would be greatly appreciated.
