Rust Inhibitor for Inside Toolbox? What Do You Use?
Fixr
SW VA
Who has found a good online source of reasonably priced camphor blocks? Lots of it online, but sketchy descriptions for a lot of it. Not available at any drugstore near me.
I spent too much time trying to find a significantly better source than Amazon and ordered these: https://www.amazon.com/dp/B09MMNWS1V?tag=atomicindus08-20 Should be here on Tuesday. And yes, it's hard to compare deals because the descriptions are often unclear.
Boogerman
aspen cove hill
the description seems pretty clear to me, except doesn't cover the toolbox uses.
Really cool factor in buying this is protects your aura from bad influences and negative energy. Put this in your toolbox and you could hang out on Reddit and Facebook instead of Garage Journal. I bet it's a best seller in California.
Fixr
SW VA
What power cords?
For the Goldenrods or other heated dehumidifiers. I didn't connect from the model number that you posted that you were talking about dessicant packs. Camphor blocks apparently work by a different mechanism than desiccants, because I get several years out of one box of camphor for all of my toolboxes. I have no idea how or why it works, but it works.
Mainiac Mat
Maine
buy a roll of VCI paper from Uline.com and use it as a drawer liner. Keep the unused portion of roll inside a dry clean area. One roll will last you a life time.
ALLFAST
You can use silica gel packets inside the drawers to absorb excess moisture in the air:
Silicagelpackets.com
They have indicating ones that turn a different color when saturated. Then you just bake them in an oven to remove the water and use them again. This isn't the method I use, but another option.
Whenever I buy a new tool and put it in my box, I spray and wipe the tool down with the same stuff I use on my firearms, GIBBS Brand. I then take a clean paper towel and wipe off the excess. Never had a tool (or firearm) rust.
I saw the light about eight years ago and use GIBBS for everything. My 1916 REM Model 11 has never looked so nice. Thanks for showing Gibbs some love. I’ve turned three friends onto it and they are highly impressed with it!
knotdust
I should have guessed.
How many people admit to using CMan sockets these days? :headscrat
I will admit to using S-K wrenches and sockets and they are over 50 years old. They don't show much rust. I usually wipe them down after use and put them back in their original tool roll or box.
Tundra1
How about go for zoro and get bonus points for style. Or at least a for conversation starter....
Tundra1
Maybe you try it out first and report back?
Hehehehe ok.
I bet it's a great way to keep people from borrowing your your tools though! No one wants to have to grab a urinal cake to steel your 10mm wrench
Recoveryman
Southern indiana
As an old time machinist, I learned early on, that to keep precision tools, I needed to observe some basics, very few shops were climate controlled. One was to wipe down tools when finished with a silicone rag at the end of the day, second was to use wooden tool chests for tools not chromed or nickle plated, and third was use camphor blocks. They used to be cheap and easy to get at drug stores. Only pierce the cellophane wrapper with a knife or sharp point. Place one in the bottom of each box. Usually chromed tools (mechanical tools like pliers or crescent wrenches went in steel boxes. Today, am retired with my own little shop that is climate controlled, heat and AC in the summer. I know that camphor blocks are not easy to find, but not a necessity any longer. In the 60's, a lot of precision tools were not chromed or nickle plated, but rust was a big no-no.
Recoveryman
Firstram
What about a small tub or bag of damp rid in the garage or toolbox to absorb the moisture?
The active ingredient in that is Calcium Chloride! 50 pound bags of ice melt are cheap and don’t smell like perfume! Buy the flake, mot the pellets, if you can.
nadogail
Coronado, CA
Assembled 90% of a Raised Bed Planter Box to give away to our housekeeper for her patio.
All that remains is drilling drainage holes and lining it with landscape fabric.
She will be able to grow tomatoes all year long.
Swincjas000
I just seen you can ship to store, at walgreens.com just order a block to your local, mine actually has it in stock, surprisingly.
