BulletsForFingers
- Joined
- Mar 21, 2015
- Messages
- 4
I just finished installing Rust-Oleum's EpoxyShield Professional. The Professional product is a solvent based epoxy. I've read that the solvent based kits do better than water based kits. I ordered mine online from Menard's. I wanted to share some numbers and pictures to hopefully help others considering this product.
Album
Mixing kits together: The instructions call for you to mix all the base cans together to get even color. I'm not going to say you shouldn't do it, but be warned it is a HUGE pain in the ***. Don't even attempt to do that step by yourself. Looking back, I'm not sure how necessary it is if you're using flakes.
Dry Times: I did one coat per evening. I was able to walk on each coat by the next day. I wouldn't try to do more than one coat per day.
Solvents: Use a respirator. Seriously, use a respirator. You could get higher than the national debt if you hung out in my garage right now. Also, solvents don't clean up as easily as water. Make sure you buy a fresh roller cover for each coat. I didn't have any problem using the same roller for multiple kits on the same day though.
Flakes: Aim high! Grab a big pinch and heave it into the ceiling. This will give you a good dispersion. Avoid dropping them from chest level or lower. Also avoid trying to "touch up" spots. If a spot isn't covered to your liking, send another handful up into the ceiling.
These have been my experiences. Happy to answer any questions.
Album
- 937 sq. ft. garage (diamond grind prepped)
- The base coat took two kits (4 gallons) exactly.
- The 2nd color coat went further. It took about 1.5 kits (3 gallons).
- the clear-coat didn't go as far as advertised. 2 kits we're supposed to go 1,000 sq. ft., but I only got ~900. I had to crack a third kit to finish.
- I used 3 bags of flakes. Rust-oleum provides 2 bags per 500sq ft kit. So I suppose I used less than they called for. However, I feel like I did a medium-heavy broadcast.
