I would recommend staying away from Rust-Oleum coating products if you want a coating that is going to last. Most of their products are residential quality DIY kits that don't last long but are fairly easy to apply. You get what you pay for in coatings. I would suggest reading the article below to learn more about what to expect from these types of kits.Brand new garage (832 sq ft ). I can't afford Race Deck but still want a good floor. What are opinions on various Rust-oleum products or should I consider something else?
First, I'd let the concrete cure for at least 6 months or maybe a year. Doing so will also give a chance to see if you have water coming up through concrete and, if so, to what degree.Brand new garage (832 sq ft ). I can't afford Race Deck but still want a good floor. What are opinions on various Rust-oleum products or should I consider something else?
It's a higher solids content (1 - 1.5 mils thicker), solvent-based epoxy with a semi-gloss finish. It's better than the water-based EpoxyShield and a better value if you are on a budget. However, it's not a "Professional" epoxy coating. It's Rust-Oleum's way of marketing it to sound as though it's commercial quality when it is not. If you want something that is "no-frills" and will last longer than 3-4 years, then it can fill the bill.What is the difference in the professional grade? Has anyone else used it?
Yep, the Professional version of the two is much better. The floor looks good!The hate on Rust-oleum, at least the "professional" line, is completely unwarranted. I do not have any experience with the water based product.
Going on 2 years now, good as the day I put it down. Admittedly, the job was 90% prep and 10% application. This is a base coat, top coat + flakes, and then a clear coat. It's all in the prep. Period.
Have you or anyone else seen/tried the Plasticpro floor titles from Costco? (did a quick search and didn't find much)Brand new garage (832 sq ft ). I can't afford Race Deck but still want a good floor. What are opinions on various Rust-oleum products or should I consider something else?
The Bad Reviews of Rust-Oleum and Quikrete Epoxy Paint Kits | All Garage Floors
Why Rust-Oleum and Quikrete epoxy paint kits don't deserve the bad reputation that they tend to get. Learn how to get the performance that you pay for.allgaragefloors.com
I would recommend purchasing a commercial quality epoxy kit from a concrete coating vendor instead. If it's in the budget, single-part polyurea is actually one of the easiest coatings to apply and will last years. We discuss them more below.
Why the Best Garage Floor Coating Kits are Single-Part Polyurea | All Garage Floors
Discover the secret of polyurea garage floor coating kits. See why they are easiest to apply, have the best protection and last 4x as long as standard epoxy.allgaragefloors.com
