Rust on ratchets?
1fastvx
I cleaned up some old tool boxes and came across some of my dads old Craftsman ratchets and extensions. Since they are real old they have a bit of surface rust on them. What is the best method of getting the rust of without ruining the finish?
Thanks,
John
HandyManny
Out West
00 or 000 steelwool. Can be used dry, with gun oil, or 3-in-1 oil. Just buff it with light even pressure. Slight surface rust harms nothing, corrosion is what you have to worry about.
dustin19
defiance ohio
extreamly fine wet/dry sandpaper with oil of some sort also works and wont leave heavy scratch marks if u use the right grain
Stuart in MN
Minneapolis
It's always best to start out with gentle cleaners before you move up to abrasives - if the surface rust is minor, try some chrome or metal polish on a rag, something like Flitz or Simichrome works well. If you don't have anything like that handy, even an auto polish/wax like Turtle Wax will probably take it off.
tj90
Use aluminum foil and coke (or diet coke). The amuminum foil is strong enough to knock down the rust with the phosphoric acid acting as a mild chemical agent. The foil is not hard enough to scratch the chrome plating if you rub with medium pressure.
I just restored an old redline bmx bike that had moderate surface rusting. Looks good as new. If the rust has penetrated the chrome, you are screwed. All you can do is knock down the rust and wax or oil to prevent more rust from forming.
Try it - it works amazingly well.
WNYflyer
Lockport, NY
I just recently cleaned up a ton of my grandfather's old tools that have been sitting in the corners of my garage for quite a awhile. A relative told me to use steel wool dipped in "DL Handcleaner" by Permatex. Worked fantastic for me primarily because it cleaned/de-greased while also removing most of the rust. For stubborn rust and hard to reach places I used Evaporust also. I think I saw DL handcleaner for good price of about $1.50 in Autozone the other day.
snapmom
Florida
It depends on if there is any plating under the rust, as to what method is best. Sometimes the wheel is the best method.
Uncle Buck
Kansas
I would totally agree with this statement, which I must admit I rarely find common ground with many on this issue. However, I will readily agree that this statement is entirely true. :thumbup::beer:
stevejh82
Just got my grinder with wire wheel hauled into the garage and ready for action, oh the humanity. With you 100% UB :bounce:
HandyManny
Out West
I've also had good luck with No.2 pencil erasers. Works great for small surface rust spots on shotguns.
Uncle Buck
Kansas
ub,how you gonna get a pencil eraser mounted on your bench grinder?
That is what I have the lathe for. I will just spin out a handy dandy adapter to hold the pencil eraser! Whip that out and I will be erasing everything in sight baby! :lol_hitti
